Signature Capture for Invoice
Last modified by David Muszynski on 2025/04/01 17:44
To turn on signature capture for invoice to achieve what you want go to Admin>Company> Value Lists T&C tab then click on the Signoff? checkbox at the top right hand corner of the T&C Invoice section.
This will then prompt you if you want to accept a signature for each invoice that is posted.
