Setting Up Touch Add Departments and Products for POS Screen
The POS Screen in CheckIn easily allows you to quickly add Products to an Invoice using the Touch Add button. However, before using this feature, Departments and Products need to be set up to display in the Touch Add section.
Enabling Touch Add Feature for Departments
Begin by navigating to the Department Setup screen for your desired Department. On the Department Setup screen, select the Touch Add tab. Insert a number into the Touch Sort field. This number will determine the order it appears in on the Touch Add pop-up.
Enabling Touch Add Feature for Products
Once you have enabled a Department for the Touch Add feature, navigate to a Product in that Department. Check off the Show Product on Touch Add checkbox at the bottom left of the Products screen. This will enable it for the Touch Add feature. Repeat this for any products in the previously enabled Department that you would like to appear on the Touch Add pop-up.
Once you have checked off all the desired Products, navigate back to the Department Setup screen. On the Department Setup screen, select the Touch Add tab. All of the enabled products will appear in the bottom right section. Insert a number into the Sort field for each line, in the order you would like the products to appear on the Touch Add pop-up. (NOTE: When removing a product from Touch Add, you must uncheck Touch Add on the Product Card AND remove it from the sort list at the Department level.
Utilizing the Touch Add button on the POS Screen
Once you have set up your Departments and Products for the Touch Add feature, you are ready to use the Touch Add button on the POS Screen.
