Version 6.4 by David Muszynski on 2025/03/28 13:40
• Admin Setup Instructions •
 1  First Time Sign In
 2  Create Your Admin & Employee Accounts
- First Name & Last Name
In the Account Information section under the Define Login Account: User Name (can just be the first name to make life simpler when logging in)
Security Group Setup: If you decide to add employees now, you first need to add more security Groups to assign to them since Admin is the only default set. To do this - stay in the same window and just go to the Security Level tab at the top and click the button to add and name a new group then click on the pencil icon to edit the group accordingly for the user you have in mind.
For a description of these security groups please see our PDF called Security Groups List in CheckIn™
 3  Company Setup Stuff: Company Info
Close the Employee List window and now back in the Admin section click on Company. This will take you to the first tab called Company Info but this info is not needed to be filled out. The only thing you need to do in this window is to add your logo. There is a generous amount of space at the top middle of each printed document for your logo. This was done on purpose in order to give you enough room to showcase your brand. (Your logo will appear in the size in which you bring it over - so you may need to resize it and bring it over again to get to your desired size.)
 4  Company Setup Stuff: Tax Info
If you are using your CheckIn server for multiple store you will need to make sure tax is set correctly for each location.
 5  Company Setup: Payment Setup
-You can modify any of the default ones except the ones noted in the Please Note section.
-The Type need to be selected but you can ignore the Account field.
Please read all text listed be each section or in sections called Please Note: in orange. These notes are important to read in this section especially.
 6  Company Setup: Stores/Sites
This is where you setup each of your Store’s information. *Please Do Not Change the Store ID #* The store information you enter here is what prints out on all your documents (Invoices, SRO, Order and Quotes). Please note the following icons and what they are for:
Screenshot 2025-03-28 at 9.33.58 AM.png  Store hours can be ignored as this is for the Apple tech retail community we serve.
Screenshot 2025-03-28 at 9.34.52 AM.png  This too can be ignored as this is for the Apple tech retail community we serve.
Screenshot 2025-03-28 at 9.35.37 AM.png  You only need to fill out this PayLink/Billing info if you want to use our PayLink feature with Fortis
 7  Company Setup: Value Lists/ T&C
In this section you have the opportunity to enter your desired Terms and Conditions as well as your custom value lists. Each section has its own tab. (Please read the Please Note in ther T&C tab)
In the Value list tab you can enter your desired values for the sections shown. We particularly like the Customer Type & Customer Referred By. This is a good idea to use and enforce all your employees to adhere to as it can assist with future marketing efforts.
 8  Company Setup: Global Setting
*CheckIn does not charge you for all the great integrations we programmed it for, but for some such as Twilio or SendGrid there may be a fee to use their platforms.
SendGrid - Twilio - Paylink
Ingram: Is a tech distributor you can get product info from and send CheckIn POs to.
SendGrid: Is the email integration option you can use to send email out directly from CheckIn.
Twilio: To send texts via an SRO.
PayLink: Allows you to email clients a payment link that links to and SRO, Order or Invoice for payments.
 9  Email
In this section you are deciding if you want to use your Apple Mail client to send emails or you can send emails via our built in FileMaker SMTP option or via SendGrid integration. The default Email Client is set which will open a new mail window in your Apple Mail App to then allow you to send an email.
For details on setting all this up please see our PDF called Email Setup Options in CheckIn™
 10  Company Setup: Default Emails
Under this tab you will have the opportunity to setup your default subject and/or default email message body when sending out emails via any of of the listed options. The variable key helps you to customize your message.
Next Steps Needed
  • If products were imported into CheckIn you need to go to the Product dashboard and then click the Department button to see a list of your departments that were brought over during the import of your products. Make sure by each department in the list has the default tax show and selected.
  • Make sure you read our PDF called CheckIn™ POS Best Practices & FYIs - (Your staff should read section 2 only)
Once you complete your Admin setup, please email us at [email protected] so we can setup a time to review your Admin settings and then we’ll setup a time for CheckIn staff training!
