Version 4.2 by David Muszynski on 2025/03/31 17:53
To access the subscription window go to the More menu and and click the button called Subscriptions and this will bring you to the main Dashboard view.
To setup PayLink please read “PayLink Setup Instructions-US Customers
The first step in this process is to setup each of your desired subscription messages for renewal and billing reminder messages. To do this, go to the Setup tab and and click the + button in the section called Subscription Messages. Give your message a Subject and a Message. (You can use the provided variable key to customize your message.) And of course Activate it in order to use it.
The Next step is to Define Subscription Types in the section of the same title. The types of subscriptions you name here will be added to the subscription section of the product card as you create each new subscription product or service.
Now you have to setup your Subscription Products for each of your desired subscription service or products within CheckIn.
There are two way to do this. You can click the + button in the Subscription Products section of the setup tab in the Subscription Management window or if you have an existing product or service product card you can open each product card and go the Subscriptions tab. First step is to activate the product or service as a subscription by checking off the Is This a Subscription Product box. Then chose the Subscription Term and then select the Reminder & Invoice Messages you want to use for those automated emails.
Chose your Reminder Method and Billing Method from the drop down lists.
★ For Billing Method Auto, the invoice will be automatically created and billed. If you choose Send Invoice - an invoice will just go out but won’t be auto billed.
★ If you are selling a product like Malwarebytes or something that requires a customer to have a key code you want to first check off Track Serial Numbers for that product then check off the Auto Issue Serial Numbers check box in order for the auto invoice of this subscription to include a serial number.
 The option called Always create a new Subscription if customer already has a subscription for existing product is just that. It will create a new subscription for a customer if they already have one instead of add the subscription to their existing one.
To set the token. Go to Admin > Company Info and click on the Paylink icon and then click on “Get Paylink Api Token“ button.
