Version 10.2 by David Muszynski on 2025/03/31 12:51
Instructions are for our US based customers only.
This PayLink feature will do the following for you: Screenshot 2025-03-31 at 8.34.44 AM.png
  • Provide a PayLink specific button on SROs, Orders and Invoices alongside your other payment button option for easy access.
  • When clicked it will either open Apple Mail along with your email template and payment link or a small email window will pop up for you to send an email or a text of the link along with the SRO, Order or Invoice.
  • Save you tons of time collecting money from customers!
  • You can use PayLink without going to Paygistix Cloud 2.0 which is the enhanced CC processing integration.
  • You can use PayLink without going to Paygistix Cloud 2.0.
  • PayLink sends out payment links for subscription management customers.
  • You can still use your existing terminals with PayLink.
  • PayLink setup is needed to use Paygistix Cloud 2.0
Setup:
1 Sign Up With PayLink
• Click on their Start Base Plan button in the Base Plan Free section.
2 Setup PayLink In CheckIn
• Click on More at the main CheckIn window and go to Admin>Company>Global Settings tab then click on the PayLink radio button to activate PayLink with a Y as show below.
• Make sure the PayLink URL is listed as: https://pay.link/payapi/ (without the word dev in it)
3 Adding PayLink In Token
• While at the same Company Setup Window, click on the Store/Sites tab
• Find the PayLink credit card icon by your current store and paste in your PayLink Token that you found on your PayLink portal. (please note that is your current version of CheckIn you may not have the PayLink icon in this section as it will reside in the Global Settings tab)
4 Adding PayLink Automation Script to FileMaker Server
In order for PayLink to automatically check for payments made by customers and to then apply them to SROs, Orders & Invoices you will need to follow the instructions below to activate a FileMaker script we created:
1. Go to the FileMaker Server Console via Safari then to >Configuration Tab >Script & Verify Schedule> Create a New schedule.
2. Schedule Type = Leave as FileMaker Script
3. Schedule Name = Give it the name Check for Payment
4. Database = CheckIn
5. Account Name & PW= Username: CheckIn Process Password: checkin
6. For FileMaker Script Choose = serverside_paylink_PaymentCheck (listed at the top)
7. Set Timeout to = 10 minutes
8. Repeat = Daily > then chose Start Date as today
9. Time = • Between (for your Store hours but pick a unique time not on the hour as to not overload server! • The Repeat = 30 minutes
10. Click out of pop up and then click Save
 2-4
Additional Information - Sending Emails
Depending on how you have your email setup will determine if Apple Mail opens up for your PayLink email to send out or if the below window opens up. If you have your email setting for Email output for Transactions under Company>Global Settings tab set to either SMTP or SendGrid, you will see the Send Email window pop up when using the PayLink button.
Setting Up Your PayLink Email & Text Templates
• Going back to Company Setup and then to Default Emails tab.
• Click PayLink radio button
• Choose Plain or HTML for your desired format (HTML will only be available when using SendGrid)
• Feel free to use the Variables Key to customize your email.
• To setup your text/SMS template use the section at the bottom named accordingly.
