UPC and Barcode for Products
Last modified by David Muszynski on 2026/01/08 18:37
The CheckIn product ID is what prints as the bar code.  But if you scan/enter the product UPC into our product's UPC field then when you scan in that barcode that is pre printed on the box it will pull up  the proper product.
Of course you can print your own product label in CheckIn but now you know the barcode is the product ID.
