Performing Physical Inventory Count
Version 2.1 by David Muszynski on 2025/03/26 15:39
Taking inventory in CheckIn is so easy you would want to do it every month!
You can also use the free FileMaker Go app on your iPhone with one or dozens of employees walking around your store using the iPhone and its camera to scan in barcodes and do quick inventory counts as well.
To begin the Inventory process in CheckIn, go to the "Products" dashboard, click on the "More" button in the Task Bar, and select "Adjust." This will open the "Inventory Adjustments" window.
Image Placeholder
