Activate Receipt Printing
Version 2.1 by David Muszynski on 2025/04/01 16:58
The default print option in CheckIn is to a standard 8x11 invoice.  To activate receipt printing in order to print to a Star TSP receipt printer you need to go to Admin> Workstation
At the setting tab search for "receipt" as shows below and select Y for "Use Receipt Printer? and add the workstation's printer ID in the field below.
