Connecting a GSX repair to an SRO
Version 2.1 by David Muszynski on 2025/03/10 14:20
If you have a manually created GSX repair and would like to tie it in, or connect it to your CheckIn SRO, you can do that easily.
When you are done creating the repair in GSX and get the GSX Repair ID you can then go to the gear icon at the bottom right of the SRO and select "Manually Enter GSX Repair ID" to enter in that GSX Repair ID# in order to associate the SRO with the GSX repair.
 From that point on you can then update the GSX repair status from within the SRO like you normally do!
